exports.policy events
exports.policy EMS events occur when ONTAP encounters issues associated with export policy configuration.
exports.policy.empty
- Severity
NOTICE
- Description
This message occurs when an export policy with no rules is assigned to a volume or a qtree. Such an empty policy makes the volume or qtree inaccessible to NFS and CIFS protocol clients.
- Corrective Action
If access is needed for the volume or qtree, then create an export policy rule using the "export-policy rule create" command.
- Syslog Message
An export policy "%s" with no rules was assigned to a %s "%s" on the Vserver %s.
- Parameters
policyName (STRING): Name of the export policy with no rules.
type (STRING): Type of object (volume or qtree).
typeName (STRING): Name of the volume or qtree.
vserver (STRING): Name of the Vserver with this issue.
exports.policy.last.rule
- Severity
ERROR
- Description
This message occurs when the last rule from the export policy assigned to a volume or qtree is deleted. An empty policy will make the volume or qtree inaccessible to clients using NFS or CIFS protocol.
- Corrective Action
- Syslog Message
The last rule from export policy "%s" was deleted on Vserver %s.
- Parameters
policyName (STRING): Name of the export policy from which the rule is being deleted.
vserver (STRING): Name of the Vserver where the issue occurs.
exports.policy.rule.limit
- Severity
ALERT
- Description
This message occurs when the export-policy rule count is beyond the supported value. This can lead to ONTAP service disruption.
- Corrective Action
There are two possible actions : - Delete one or more existing export policy rule using the "vserver export-policy rule delete" command. - Use an existing export policy rule that is configured the same way as the desired new rule. Modify the existing rule's "-clientmatch" property to include the client list/netgroups/netmask/domain needing to be added. See the "vserver export-policy rule modify" man page for more details.For more information, contactNetApp technical support.
- Syslog Message
The current cluster export policy rule count %s rules has crossed the supported value of %s rules.
- Parameters
currentRuleCount (STRING): Count of the export policy rules.
ruleLimit (STRING): Count of the export policy rule cluster limit.
