wafl.write events
wafl.write.fail.cifsSpace
Severity
ERROR
This message occurs when a write to a file with CIFS-style space reservations fails due to a lack of space in the volume or aggregate.
Corrective Action
If the volume is a Flexvol® volume, and the volume guarantee is disabled, increase the amount of space available in the aggregate. Otherwise, increase the amount of space available in the volume.
Syslog Message
Write failed to file with CIFS space reservations due to lack of disk space in %s %s%s%s%s (%s%s, inode %u, offset %llu, len %u).
type (STRING): Type of object (volume/aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
space_info (STRING): Text string specifying whether there is a guarantee.
guarantee_state (STRING): Text string describing the state of the guarantee on the volume (disabled, volume, file, and so on).
ino (INT): Inode number.
offset (LONGINT): Block offset.
len (INT): Length value.
wafl.write.fail.spcres
Severity
ERROR
This message occurs when a write to a space-reserved file fails due to a lack of space in the volume or aggregate. This is possible when the fractional reserve is not 100% or the space guarantee of the containing flexible volume is not guaranteed.
Corrective Action
Syslog Message
Write failed to file with space reservations due to lack of disk space in %s %s%s%s%s (%s%s, inode %u, offset %llu, len %u).
