wafl.write events
Creating your file...
wafl.write.fail.cifsSpace
- Severity
ERROR
- Description
This message occurs when a write to a file with CIFS-style space reservations fails due to a lack of space in the volume or aggregate.
- Corrective Action
If the volume is a Flexvol® volume, and the volume guarantee is disabled, increase the amount of space available in the aggregate. Otherwise, increase the amount of space available in the volume.
- Syslog Message
Write failed to file with CIFS space reservations due to lack of disk space in %s %s%s%s%s (%s%s, inode %u, offset %llu, len %u).
- Parameters
type (STRING): Type of object (volume/aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
space_info (STRING): Text string specifying whether there is a guarantee.
guarantee_state (STRING): Text string describing the state of the guarantee on the volume (disabled, volume, file, and so on).
ino (INT): Inode number.
offset (LONGINT): Block offset.
len (INT): Length value.
wafl.write.fail.spcres
- Severity
ERROR
- Description
This message occurs when a write to a space-reserved file fails due to a lack of space in the volume or aggregate. This is possible when the fractional reserve is not 100% or the space guarantee of the containing flexible volume is not guaranteed.
- Corrective Action
- Syslog Message
Write failed to file with space reservations due to lack of disk space in %s %s%s%s%s (%s%s, inode %u, offset %llu, len %u).
- Parameters
