The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rbac.spuser events
Creating your file...
Your file is ready
rbac.spuser.role.notfound
- Severity
ERROR
- Description
This message occurs when the role that was earlier associated with the service-processor application user in a previous release was deleted in the current release and is not found during a revert to a previous release.
- Corrective Action
Re-create the deleted role for the service-processor application user using the command "security login role create".
- Syslog Message
Role "%s" for service-processor user "%s" was not found on SVM "%s".
- Parameters
role_name (STRING): Name of the role which was deleted.
user_name (STRING): Name of the user for which the role modification failed.
vserver_name (STRING): Name of the SVM.
