wafl.pvbn events
wafl.pvbn.check.done
Severity
INFORMATIONAL
This event is issued to inform the user that the pvbn check has completed. It lists detailed information on what work was performed.
Corrective Action
This message may be disabled by passing -s to wafl scan pvbn_check when starting the scanner.
Syslog Message
PVBN check has completed on %s, snapid %d. inos: %d, pvbns: %llu, unks: %llu, errs: %llu.
vol (STRING): The volume name
snapid (INT): ID of the snapshot that has been completely scanned
inos (INT): How many inodes were checked
pvbns (LONGINT): How many block pointers were checked
unks (LONGINT): How many pvbn unknowns were encountered
errs (LONGINT): How many pvbn mismatches were encountered
wafl.pvbn.check.found.mismatch
Severity
EMERGENCY
This event is issued to inform the user that the pvbn check has found a pvbn mismatch.
Corrective Action
Syslog Message
PVBN check has found a pvbn mismatch on %s, snapid=%d, %s ino=%d, level=%d, fbn=%llu, index=%d, pvbn=%llu, pvbn2=%llu.
snapid (INT): ID of the snapshot being scanned
ino_type (STRING): The inode type
inum (INT): Inum being scanned
level (INT): Level of the buftree being scanned
fbn (LONGINT): Block number containing unknown
index (INT): Index in block that is unknown
pvbn (LONGINT): PVBN as found in the buftree
pvbn2 (LONGINT): PVBN as found in the container indirect
wafl.pvbn.check.found.unknown
Severity
NOTICE
This event is issued to inform the user that the pvbn check has found a pvbn unknown.
Corrective Action
Syslog Message
PVBN check has found a pvbn unknown on %s, snapid=%d, %s ino=%d, level=%d, fbn=%llu, index=%d.
wafl.pvbn.check.no.snapshot
Severity
INFORMATIONAL
This event is issued to inform the user that the snapshot being scanned by the pvbn checker no longer exists.
Corrective Action
Syslog Message
PVBN check on %s aborted, snapshot with snapid %d is gone.
snapid (INT): ID of the snapshot that no longer exists
