wafl.pvbn events
Creating your file...
wafl.pvbn.check.done
- Severity
INFORMATIONAL
- Description
This event is issued to inform the user that the pvbn check has completed. It lists detailed information on what work was performed.
- Corrective Action
This message may be disabled by passing -s to wafl scan pvbn_check when starting the scanner.
- Syslog Message
PVBN check has completed on %s, snapid %d. inos: %d, pvbns: %llu, unks: %llu, errs: %llu.
- Parameters
vol (STRING): The volume name
snapid (INT): ID of the snapshot that has been completely scanned
inos (INT): How many inodes were checked
pvbns (LONGINT): How many block pointers were checked
unks (LONGINT): How many pvbn unknowns were encountered
errs (LONGINT): How many pvbn mismatches were encountered
wafl.pvbn.check.found.mismatch
- Severity
EMERGENCY
- Description
This event is issued to inform the user that the pvbn check has found a pvbn mismatch.
- Corrective Action
- Syslog Message
PVBN check has found a pvbn mismatch on %s, snapid=%d, %s ino=%d, level=%d, fbn=%llu, index=%d, pvbn=%llu, pvbn2=%llu.
- Parameters
snapid (INT): ID of the snapshot being scanned
ino_type (STRING): The inode type
inum (INT): Inum being scanned
level (INT): Level of the buftree being scanned
fbn (LONGINT): Block number containing unknown
index (INT): Index in block that is unknown
pvbn (LONGINT): PVBN as found in the buftree
pvbn2 (LONGINT): PVBN as found in the container indirect
wafl.pvbn.check.found.unknown
- Severity
NOTICE
- Description
This event is issued to inform the user that the pvbn check has found a pvbn unknown.
- Corrective Action
- Syslog Message
PVBN check has found a pvbn unknown on %s, snapid=%d, %s ino=%d, level=%d, fbn=%llu, index=%d.
- Parameters
wafl.pvbn.check.no.snapshot
- Severity
INFORMATIONAL
- Description
This event is issued to inform the user that the snapshot being scanned by the pvbn checker no longer exists.
- Corrective Action
- Syslog Message
PVBN check on %s aborted, snapshot with snapid %d is gone.
- Parameters
snapid (INT): ID of the snapshot that no longer exists
