The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netport.eth events
Creating your file...
Your file is ready
netport.eth.discovered
- Severity
NOTICE
- Description
This message occurs when a physical network port has been discovered.
- Corrective Action
(None).
- Syslog Message
Physical network port %s (node %s) has been discovered.
- Parameters
port (STRING): Name of the network port.
node (STRING): Name of the node on which the network port resides.
