The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
bootfs.env events
Creating your file...
Your file is ready
bootfs.env.issue
- Severity
ERROR
- Description
This message occurs when an error is detected while trying to access the environment file stored on the boot device. Environment variables on the system cannot be changed or saved.
- Corrective Action
Reformat or replace the boot media. If the problem persists, contact NetApp technical support.
- Syslog Message
Environmental variables cannot be accessed or saved on the boot device (%s).
- Parameters
err_str (STRING): Error string.
