ONTAP EMS reference
bootfs.env events
bootfs.env EMS events occur when an error is detected while trying to access the environment file stored on the boot device.
bootfs.env.issue
Severity
ERROR
This message occurs when an error is detected while trying to access the environment file stored on the boot device. Environment variables on the system cannot be changed or saved.
Corrective Action
Reformat or replace the boot media. If the problem persists, contact NetApp technical support.
Syslog Message
Environmental variables cannot be accessed or saved on the boot device (%s).
err_str (STRING): Error string.
