mgmt.exovol events
mgmt.exovol.transfer.failed
Severity
ERROR
This message occurs when the replication engine fails to transfer exo-volume data.
Corrective Action
If problem persists, Contact NetApp technical support.
Syslog Message
The replication for volume dsid %jd, transfer-id %s failed to transfer %s exo-volume data, error: %d, failure reason: %s, extended failure reason: %s.
volDsid (LONGINT): Data set identifier of the volume.
transferId (STRING): Replication transfer id.
streamType (STRING): Type of data being transferred.
error (INT): Transfer failure error code.
failureReason (STRING): Basic reason for the failure.
extendendFailureReason (STRING): Detailed reason for the failure.
mgmt.exovol.xfer.dest.no.space
Severity
ERROR
This message occurs when there is no free space left on the destination aggregate.
Corrective Action
Please increase the amount of free space available on the destination aggregate.
Syslog Message
The replication for volume dsid %jd, transfer-id %s failed to transfer %s exo-volume data because there is no free space left on the destination aggregate.
