mgmt.exovol events
Creating your file...
mgmt.exovol.transfer.failed
- Severity
ERROR
- Description
This message occurs when the replication engine fails to transfer exo-volume data.
- Corrective Action
If problem persists, Contact NetApp technical support.
- Syslog Message
The replication for volume dsid %jd, transfer-id %s failed to transfer %s exo-volume data, error: %d, failure reason: %s, extended failure reason: %s.
- Parameters
volDsid (LONGINT): Data set identifier of the volume.
transferId (STRING): Replication transfer id.
streamType (STRING): Type of data being transferred.
error (INT): Transfer failure error code.
failureReason (STRING): Basic reason for the failure.
extendendFailureReason (STRING): Detailed reason for the failure.
mgmt.exovol.xfer.dest.no.space
- Severity
ERROR
- Description
This message occurs when there is no free space left on the destination aggregate.
- Corrective Action
Please increase the amount of free space available on the destination aggregate.
- Syslog Message
The replication for volume dsid %jd, transfer-id %s failed to transfer %s exo-volume data because there is no free space left on the destination aggregate.
- Parameters
