vscan.pool events
vscan.pool.autoActivated
Severity
INFORMATIONAL
This message occurs when the Vscan scanner pool is automatically activated.
Corrective Action
(None).
Syslog Message
Vscan scanner pool '%s' is automatically activated on Vserver '%s'.
scannerPool (STRING): Name of the scanner pool.
vserverName (STRING): Name of the Vserver.
vscan.pool.autoDeactivated
Severity
INFORMATIONAL
This message occurs when the Vscan scanner pool is automatically deactivated.
Corrective Action
(None).
Syslog Message
Vscan scanner pool '%s' is automatically deactivated on Vserver '%s'.
vscan.pool.largeReqTimeout
Severity
NOTICE
This message occurs when the request timeout of a Vscan scanner pool is configured more than what can be honored for an On-Access policy whose scan-mandatory option is set to "off". The system internally adjusts the request timeout to the maximum allowed value.
Corrective Action
(None).
Syslog Message
For scanner-pool '%s' created on Vserver '%s', request-timeout is configured as %ds but that would internally be taken as %ds if the applicable On-Access policy has scan-mandatory set to "off". This ensures that the file-access is granted to the client for such policy.
vserverName (STRING): Name of the Vserver on which the scanner pool is configured.
requestTimeout (INT): Request timeout value configured by the user.
adjustedRequestTimeout (INT): Request timeout value that the system internally adjusts to.
