ONTAP EMS reference
vscan.pool events
vscan.pool EMS events occur when ONTAP encounters issues associated with Vscan scanner pool activation or configuration.
vscan.pool.autoActivated
Severity
INFORMATIONAL
This message occurs when the Vscan scanner pool is automatically activated.
Corrective Action
(None).
Syslog Message
Vscan scanner pool '%s' is automatically activated on Vserver '%s'.
scannerPool (STRING): Name of the scanner pool.
vserverName (STRING): Name of the Vserver.
vscan.pool.autoDeactivated
Severity
INFORMATIONAL
This message occurs when the Vscan scanner pool is automatically deactivated.
Corrective Action
(None).
Syslog Message
Vscan scanner pool '%s' is automatically deactivated on Vserver '%s'.
vscan.pool.largeReqTimeout
Severity
NOTICE
This message occurs when the request timeout of a Vscan scanner pool is configured more than what can be honored for an On-Access policy whose scan-mandatory option is set to "off". The system internally adjusts the request timeout to the maximum allowed value.
Corrective Action
(None).
Syslog Message
For scanner-pool '%s' created on Vserver '%s', request-timeout is configured as %ds but that would internally be taken as %ds if the applicable On-Access policy has scan-mandatory set to "off". This ensures that the file-access is granted to the client for such policy.
vserverName (STRING): Name of the Vserver on which the scanner pool is configured.
requestTimeout (INT): Request timeout value configured by the user.
adjustedRequestTimeout (INT): Request timeout value that the system internally adjusts to.
