ONTAP EMS reference
wafl.offline events
wafl.offline EMS events occur when ONTAP encounters issues associated with volume online operations and metadata access.
wafl.offline.infoError
Severity
ALERT
This message occurs when the system attempts to place a volume online, but cannot read the volinfo or fsinfo data for the volume.
Corrective Action
Volume is inconsistent. Contact NetApp technical support.
Syslog Message
Either both volinfo blocks or fsinfo block on %s %s%s%s%s are/is invalid.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume, for cases when the volume name is insufficient.
wafl.offline.openfiles
Severity
NOTICE
This message occurs when wafliron detects a failure while trying to perform an operation because files are open.
Corrective Action
No corrective action is required for this notification event.
Syslog Message
'%s %s' might not be '%s%s' because of '%u' open file'%s'.
voltype (STRING): Aggregate.
volname (STRING): Volume name.
operation (STRING): Operation.
suffix (STRING): Suffix.
uses (INT): Number of open files.
plural (STRING): Plural.
wafl.offline.proc.file
Severity
NOTICE
This message occurs when wafliron detects a failure while trying to perform an operation because a process has open files.
Corrective Action
Syslog Message
The '%s' process has '%u' file'%s' open.
procname (STRING): Process name.
openfiles (INT): Number of open files.
wafl.offline.proc.file.unres
Severity
NOTICE
This message occurs when wafliron detects a failure while trying to perform an operation because a process has unresolved open files.
Corrective Action
Syslog Message
Could not resolve '%u' of '%s's' open file names.
wafl.offline.quiesce.aborted
Severity
NOTICE
This message occurs when wafliron detects a failure while waiting for a volume reference lock to be taken.
Corrective Action
Syslog Message
The wait for uses of '%s %s' to quiesce was aborted.
aggrname (STRING): Aggregate name.
wafl.offline.quiesced
Severity
NOTICE
This message occurs when wafliron detects a success while waiting for a volume reference lock to be taken.
Corrective Action
Syslog Message
Uses of '%s %s' preventing '%s' have quiesced.
wafl.offline.versionMismatch
Severity
EMERGENCY
This message occurs when the system is inspecting an offline volume by reading the super block and discovers that there is a version mismatch.
Corrective Action
Confirm that the correct Data ONTAP® version is in use; if not, reboot or upgrade to the correct version as necessary. For more information or assistance, contact NetApp technical support.
Syslog Message
This version of Data ONTAP does not recognize the filesystem of offline %s %s%s%s%s. The volume is probably from a later version of the software.
type (STRING): Type of object (volume/aggregate).
volident (STRING): Unique identifier of the volume in cases in which the volume name itself is insufficient.
wafl.offline.volref.msg
Severity
NOTICE
This message indicates the volume reference message that prevents the operation on an aggregate.
Corrective Action
Syslog Message
'%s' prevents '%s' of '%s %s'.
volreftext (STRING): Volume reference message text.
