wafl.offline events
Creating your file...
wafl.offline.infoError
- Severity
ALERT
- Description
This message occurs when the system attempts to place a volume online, but cannot read the volinfo or fsinfo data for the volume.
- Corrective Action
Volume is inconsistent. Contact NetApp technical support.
- Syslog Message
Either both volinfo blocks or fsinfo block on %s %s%s%s%s are/is invalid.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume, for cases when the volume name is insufficient.
wafl.offline.openfiles
- Severity
NOTICE
- Description
This message occurs when wafliron detects a failure while trying to perform an operation because files are open.
- Corrective Action
No corrective action is required for this notification event.
- Syslog Message
'%s %s' might not be '%s%s' because of '%u' open file'%s'.
- Parameters
voltype (STRING): Aggregate.
volname (STRING): Volume name.
operation (STRING): Operation.
suffix (STRING): Suffix.
uses (INT): Number of open files.
plural (STRING): Plural.
wafl.offline.proc.file
- Severity
NOTICE
- Description
This message occurs when wafliron detects a failure while trying to perform an operation because a process has open files.
- Corrective Action
- Syslog Message
The '%s' process has '%u' file'%s' open.
- Parameters
procname (STRING): Process name.
openfiles (INT): Number of open files.
wafl.offline.proc.file.unres
- Severity
NOTICE
- Description
This message occurs when wafliron detects a failure while trying to perform an operation because a process has unresolved open files.
- Corrective Action
- Syslog Message
Could not resolve '%u' of '%s's' open file names.
- Parameters
wafl.offline.quiesce.aborted
- Severity
NOTICE
- Description
This message occurs when wafliron detects a failure while waiting for a volume reference lock to be taken.
- Corrective Action
- Syslog Message
The wait for uses of '%s %s' to quiesce was aborted.
- Parameters
aggrname (STRING): Aggregate name.
wafl.offline.quiesced
- Severity
NOTICE
- Description
This message occurs when wafliron detects a success while waiting for a volume reference lock to be taken.
- Corrective Action
- Syslog Message
Uses of '%s %s' preventing '%s' have quiesced.
- Parameters
wafl.offline.versionMismatch
- Severity
EMERGENCY
- Description
This message occurs when the system is inspecting an offline volume by reading the super block and discovers that there is a version mismatch.
- Corrective Action
Confirm that the correct Data ONTAP® version is in use; if not, reboot or upgrade to the correct version as necessary. For more information or assistance, contact NetApp technical support.
- Syslog Message
This version of Data ONTAP does not recognize the filesystem of offline %s %s%s%s%s. The volume is probably from a later version of the software.
- Parameters
type (STRING): Type of object (volume/aggregate).
volident (STRING): Unique identifier of the volume in cases in which the volume name itself is insufficient.
wafl.offline.volref.msg
- Severity
NOTICE
- Description
This message indicates the volume reference message that prevents the operation on an aggregate.
- Corrective Action
- Syslog Message
'%s' prevents '%s' of '%s %s'.
- Parameters
volreftext (STRING): Volume reference message text.
