ONTAP EMS reference
nblade.vscanconninactive events
nblade.vscanconninactive EMS events occur when ONTAP® detects a nonresponsive antivirus (AV) server and forcibly closes its vscan connection.
Nblade.vscanConnInactive
Severity
NOTICE
This message occurs when ONTAP® detects a nonresponsive antivirus (AV) server and forcibly closes its vscan connection.
Corrective Action
Ensure that the AV Connector, installed on the AV server, can connect to the Vserver and receive the scan requests.
Syslog Message
For Vserver "%s", ONTAP® forcibly closed the vscan connection originated from the nonresponsive AV server "%s".
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the AV server.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
