The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cpeer.modify events
Creating your file...
Your file is ready
cpeer.modify.address.family
- Severity
NOTICE
- Description
This message occurs when the address family for a peering relationship is modified. The same configuration change should be made at the peered cluster in a timely manner. Peering services are maintained while intercluster LIFs of both address families are configured on each cluster.
- Corrective Action
This is a notification of a configuration change. No corrective action applies.
- Syslog Message
Address family change for peer cluster %s to address family %s.
- Parameters
peer (STRING): Name of the peer cluster affected by the address family change.
family (STRING): The new address family of the peering relationship.
