cpeer.modify events
Creating your file...
Your file is ready
cpeer.modify.address.family
- Severity
NOTICE
- Description
This message occurs when the address family for a peering relationship is modified. The same configuration change should be made at the peered cluster in a timely manner. Peering services are maintained while intercluster LIFs of both address families are configured on each cluster.
- Corrective Action
This is a notification of a configuration change. No corrective action applies.
- Syslog Message
Address family change for peer cluster %s to address family %s.
- Parameters
peer (STRING): Name of the peer cluster affected by the address family change.
family (STRING): The new address family of the peering relationship.
