smbc.cg events
smbc.cg.info.read.failed
Severity
ERROR
This message occurs when read of Consistency Group aggregate information entry fails for the SnapMirror® Business Continuity (SMBC) volume which results into IO disruption.
Corrective Action
To recover from this situation, perform below steps : Run wafliron on the aggregate hosting the SMBC volume which failed during mount time. Run resync on all the SMBC CG relationships present in the aggregate on which wafliron executed.
Syslog Message
Read of Consistency Group aggregate information entry failed for source volume DSID: "%llu" during "%s" because Consistency Group aggregate information file is corrupted.
source_volume_dsid (LONGINT): Source Volume DSID
operation (STRING): Name of operation
smbc.cg.info.update.failed
Severity
ERROR
This message occurs when add or delete of Consistency Group aggregate information entry fails for the SnapMirror® Business Continuity (SMBC) volume which results into IO disruption.
Corrective Action
Syslog Message
"%s" of Consistency Group aggregate information entry failed for source volume DSID: "%llu" because Consistency Group aggregate information file is corrupted.
metafile_update_type (STRING): Name of aggregate metafile update type
volume_dsid (LONGINT): Volume DSID
