smbc.cg events
smbc.cg EMS events occur when ONTAP encounters issues associated with SnapMirror® active sync Consistency Group operations.
smbc.cg.info.read.failed
- Severity
ERROR
- Description
This message occurs when read of Consistency Group aggregate information entry fails for the SnapMirror® Business Continuity (SMBC) volume which results into IO disruption.
- Corrective Action
To recover from this situation, perform below steps : Run wafliron on the aggregate hosting the SMBC volume which failed during mount time. Run resync on all the SMBC CG relationships present in the aggregate on which wafliron executed.
- Syslog Message
Read of Consistency Group aggregate information entry failed for source volume DSID: "%llu" during "%s" because Consistency Group aggregate information file is corrupted.
- Parameters
source_volume_dsid (LONGINT): Source Volume DSID
operation (STRING): Name of operation
smbc.cg.info.update.failed
- Severity
ERROR
- Description
This message occurs when add or delete of Consistency Group aggregate information entry fails for the SnapMirror® Business Continuity (SMBC) volume which results into IO disruption.
- Corrective Action
- Syslog Message
"%s" of Consistency Group aggregate information entry failed for source volume DSID: "%llu" because Consistency Group aggregate information file is corrupted.
- Parameters
metafile_update_type (STRING): Name of aggregate metafile update type
volume_dsid (LONGINT): Volume DSID
