smbc.cg events
smbc.cg.info.read.failed
- Severity
ERROR
 - Description
This message occurs when read of Consistency Group aggregate information entry fails for the SnapMirror® active sync volume which results into IO disruption.
 - Corrective Action
To recover from this situation, perform below steps : Run wafliron on the aggregate hosting the SnapMirror® active sync volume which failed during mount time. Run resync on all the SnapMirror® active sync CG relationships present in the aggregate on which wafliron executed.
 - Syslog Message
Read of Consistency Group aggregate information entry failed for source volume DSID: "%llu" during "%s" because Consistency Group aggregate information file is corrupted.
 - Parameters
source_volume_dsid (LONGINT): Source Volume DSID
operation (STRING): Name of operation
smbc.cg.info.update.failed
- Severity
ERROR
 - Description
This message occurs when add or delete of Consistency Group aggregate information entry fails for the SnapMirror® active sync volume which results into IO disruption.
 - Corrective Action
 - Syslog Message
"%s" of Consistency Group aggregate information entry failed for source volume DSID: "%llu" because Consistency Group aggregate information file is corrupted.
 - Parameters
metafile_update_type (STRING): Name of aggregate metafile update type
volume_dsid (LONGINT): Volume DSID
