image.install events
image.install EMS events occur when ONTAP encounters issues associated with ONTAP software installation operations.
image.install.fail.aggregate
- Severity
ERROR
- Description
This message occurs when a software image installation fails, because one or more aggregates or volumes are not online.
- Corrective Action
Ensure that aggregates and volumes are all online by using the "storage aggregate show -state !online" command and the "volume show -state !online -state !restricted" command.
- Syslog Message
"Image installation fail: One or more aggregates are not online"
- Parameters
(None).
image.install.fail.mcluster
- Severity
ERROR
- Description
This message occurs when a software image installation fails because a MetroCluster(tm) switchover operation is in progress or already switched over.
- Corrective Action
Use the "metrocluster show" command to verify that both the local and remote clusters are neither performing switchover nor in switchover mode.
- Syslog Message
"MetroCluster switchover operation is in progress or already switched over."
- Parameters
(None).
image.install.fail.sfostate
- Severity
ERROR
- Description
This message occurs when a software image installation fails because the node is in takeover state.
- Corrective Action
Ensure that all storage failover operations have been completed and that no nodes remain taken over by using the "storage failover show-giveback" command, and then try the installation again.
- Syslog Message
"The node is taken over, cannot set to new image."
- Parameters
(None).
image.install.fail.sign
- Severity
ALERT
- Description
This message occurs when the software installation process cannot verify the digital signature of the intended image.
- Corrective Action
Replace the image, and then try the command again.
- Syslog Message
"Image installation fail: Image digital signature check failed."
- Parameters
(None).
