image.install events
image.install.fail.aggregate
Severity
ERROR
This message occurs when a software image installation fails, because one or more aggregates or volumes are not online.
Corrective Action
Ensure that aggregates and volumes are all online by using the "storage aggregate show -state !online" command and the "volume show -state !online -state !restricted" command.
Syslog Message
"Image installation fail: One or more aggregates are not online"
(None).
image.install.fail.mcluster
Severity
ERROR
This message occurs when a software image installation fails because a MetroCluster(tm) switchover operation is in progress or already switched over.
Corrective Action
Use the "metrocluster show" command to verify that both the local and remote clusters are neither performing switchover nor in switchover mode.
Syslog Message
"MetroCluster switchover operation is in progress or already switched over."
(None).
image.install.fail.sfostate
Severity
ERROR
This message occurs when a software image installation fails because the node is in takeover state.
Corrective Action
Ensure that all storage failover operations have been completed and that no nodes remain taken over by using the "storage failover show-giveback" command, and then try the installation again.
Syslog Message
"The node is taken over, cannot set to new image."
(None).
image.install.fail.sign
Severity
ALERT
This message occurs when the software installation process cannot verify the digital signature of the intended image.
Corrective Action
Replace the image, and then try the command again.
Syslog Message
"Image installation fail: Image digital signature check failed."
(None).
