The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mcc.check events
Creating your file...
Your file is ready
mcc.check.failed
- Severity
ERROR
- Description
This message occurs when the MetroCluster (tm) check job has failed to complete all checks for the system.
- Corrective Action
Run "metrocluster operation history show" command to check the reason for this failure. Make sure that all nodes in each of the clusters are healthy, and both clusters are in normal mode using the "metrocluster node show" and "metrocluster show" commands. Then retry the operation using the command "metrocluster check run". If the problem persists, contact NetApp technical support.
- Syslog Message
The MetroCluster (tm) check job has failed to complete all checks for the system in cluster %s.
- Parameters
Cluster (STRING): Cluster where the check was running.
