certificate.node events
certificate.node.vserver
Severity
ERROR
This message occurs when an installed certificate record exists in a node Vserver. Such records are not treated consistently by the system, but were unintentionally permitted in prior releases.
Corrective Action
Delete the problematic record by using the "security certificate delete" command.
Syslog Message
The certificate record with UUID %s, named "%s" is installed in the node Vserver "%s".
uuid (STRING): UUID of the offending record.
cert_name (STRING): Name (unique within a Vserver) of the offending record.
vserver (STRING): Name of the node Vserver in which the offending record is installed.
