      certificate.node events
certificate.node.vserver
- Severity
ERROR
 - Description
This message occurs when an installed certificate record exists in a node Vserver. Such records are not treated consistently by the system, but were unintentionally permitted in prior releases.
 - Corrective Action
Delete the problematic record by using the "security certificate delete" command.
 - Syslog Message
The certificate record with UUID %s, named "%s" is installed in the node Vserver "%s".
 - Parameters
uuid (STRING): UUID of the offending record.
cert_name (STRING): Name (unique within a Vserver) of the offending record.
vserver (STRING): Name of the node Vserver in which the offending record is installed.
