raid.label events
Creating your file...
raid.label.io.readError
- Severity
NOTICE
- Description
This message occurs when a RAID label read I/O failure is detected. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
- Corrective Action
(None).
- Syslog Message
Label read on %s failed with storage error %s. The system will stop using the disk for I/O operations.
- Parameters
disk_info (STRING): Formatted information about the disk.
error_str (STRING): Error string.
instanceFile (STRING): Internal file code.
instanceId (INT): Internal instance identifier.
shelf (STRING): Identifier of the shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Character string representing the model of the disk drive.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk drive.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.label.io.revertError
- Severity
NOTICE
- Description
This message occurs when a RAID label revert to consistent state fails during assimilation. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
- Corrective Action
(None).
- Syslog Message
Label revert on plex %s, %s failed.
- Parameters
plex (STRING): Name of the containing plex.
raid.label.io.writeError
- Severity
NOTICE
- Description
This message occurs when a RAID label write I/O failure is detected. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
- Corrective Action
(None).
- Syslog Message
Label write on %s failed with storage error %s. The system will stop using the disk for I/O operations.
- Parameters
raid.label.raidarea.invalidVersion
- Severity
NOTICE
- Description
This message occurs when the system discovers that a disk has a RAIDArea object version of 0, which is invalid. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
- Corrective Action
(None).
- Syslog Message
%s has %s RAIDArea object with a version (%d) that is not supported (the current object version is %d).
- Parameters
type (STRING): RAIDArea object type.
version (INT): RAIDArea object version.
currentVersion (INT): Current version of this RAIDArea object type supported by the software.
model (STRING): Character string representing the model of the disk.
disk_type (INT): Type of disk.
raid.label.raidarea.tooRecent
- Severity
NOTICE
- Description
This message occurs when the system discovers that a disk has an invalid RAIDArea object version. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
- Corrective Action
(None).
- Syslog Message
%s has %s raidarea object with a version (%d) more recent than the currently supported version (%d).
- Parameters
