ONTAP EMS reference
nblade.vldb events
nblade.vldb EMS events occur when ONTAP encounters issues associated with volume location database (VLDB) operations.
Nblade.vldb.LeakedBladeList
Severity
ALERT
This message occurs when a protocol requests a list of blades, the current blade list is too old, and a new list needs to be generated. However, one or more references given to the previous requests has not yet been released.
Corrective Action
To restore proper operation of the affected protocol, a reboot of the node will be required. Rebooting the node with the "system node reboot -dump true" command saves a core dump that allows diagnosis of this issue by NetApp technical support. For more information or assistance, contact NetApp technical support.
Syslog Message
%s operation issued by %s on cached VLDB blade list with references pending beyond expiry time.
operation (STRING): Type of operation the caller is attempting.
caller (STRING): Caller that is trying to perform the operation.
Nblade.vldb.Timeout
Severity
ERROR
This message occurs when a request from the network module to the volume location database (VLDB) times out. The VLDB is used to identify the node that currently controls a volume. This might be a transient condition. If the condition persists, some volumes might be inaccessible.
Corrective Action
Contact NetApp technical support.
Syslog Message
Request from the network module to the volume location database (VLDB) timed out.
(None).
