ONTAP EMS reference
nblade.vldb events
nblade.vldb EMS events occur when ONTAP encounters issues associated with volume location database (VLDB) operations.
Nblade.vldb.LeakedBladeList
Severity
NOTICE
This message occurs when a protocol requests a list of blades but one cannot be generated due to one or more references to a previous request or requests still outstanding.
Corrective Action
If this condition is not cleared by a subsequent free message within 30 minutes, a reboot of the node might be required. Rebooting the node with the "system node reboot -dump true" command saves a core dump that allows diagnosis of this issue by NetApp technical support. For more information or assistance, contact NetApp technical support.
Syslog Message
"%s" operation issued by "%s" on cached volume location database (VLDB) blade list with references pending beyond expiry time.
operation (STRING): Type of operation the caller is attempting.
caller (STRING): Caller that is trying to perform the operation.
Nblade.vldb.Timeout
Severity
ERROR
This message occurs when a request from the network module to the volume location database (VLDB) times out. The VLDB is used to identify the node that currently controls a volume. This might be a transient condition. If the condition persists, some volumes might be inaccessible.
Corrective Action
Contact NetApp technical support.
Syslog Message
%s request from the network module to the VLDB times out.
pMessage (STRING): Message to indicate the function that triggers the error.
