ONTAP EMS reference
maxcid.threshold events
maxCID.threshold.exceeded
Severity
ERROR
This message occurs when the system is approaching the maximum number of open data connections supported on the node.
Corrective Action
Balance the network load across all nodes within the cluster.
Syslog Message
Number of active data connections is %d and maximum supported threshold is %d.
activeCID (INT): Number of open data connections on the node.
maxCIDThreshold (INT): Maximum threshold of data connections supported per node.
