maxcid.threshold events
maxCID.threshold.exceeded
- Severity
ERROR
- Description
This message occurs when the system is approaching the maximum number of open data connections supported on the node.
- Corrective Action
Balance the network load across all nodes within the cluster.
- Syslog Message
Number of active data connections is %d and maximum supported threshold is %d.
- Parameters
activeCID (INT): Number of open data connections on the node.
maxCIDThreshold (INT): Maximum threshold of data connections supported per node.
