The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
maxcid.threshold events
Creating your file...
Your file is ready
maxCID.threshold.exceeded
- Severity
ERROR
- Description
This message occurs when the system is approaching the maximum number of open data connections supported on the node.
- Corrective Action
Balance the network load across all nodes within the cluster.
- Syslog Message
Number of active data connections is %d and maximum supported threshold is %d.
- Parameters
activeCID (INT): Number of open data connections on the node.
maxCIDThreshold (INT): Maximum threshold of data connections supported per node.
