The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
acp.update events
Creating your file...
Your file is ready
acp.update.failed
- Severity
ERROR
- Description
This message occurs when the Alternate Control Path (ACP) Administrator receives notification from the ACP Processor that it cannot upgrade the firmware because it is in some faulty state or the firmware file is not valid. The ACP processor will continue to run with the older firmware version.
- Corrective Action
Try issuing the firmware download again using the "system node run -node <nodename> -command storage download acp" command.
- Syslog Message
ACP module %s (%s) failed to upgrade firmware, (disk shelf serial number: %s).
- Parameters
inband_id (STRING): Inband ID of the module.
ip (STRING): IP address of the module.
shelf_sno (STRING): Disk shelf serial number of the shelf where this I/O module is seated.
