The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.vscanconnreqonsmb1 events
Creating your file...
Your file is ready
Nblade.vscanConnReqOnSMB1
- Severity
ERROR
- Description
This message occurs during a client attempt to establish a vscan connection over SMB1, which is not supported.
- Corrective Action
Verify that both the client and Data ONTAP® support and are configured for SMB2 or later.
- Syslog Message
For Vserver "%s", the vscan connection request coming from the client "%s" is rejected because it is not supported for SMB1.
- Parameters
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the client.
