nblade.vscanconnreqonsmb1 events
Creating your file...
Your file is ready
Nblade.vscanConnReqOnSMB1
- Severity
ERROR
- Description
This message occurs during a client attempt to establish a vscan connection over SMB1, which is not supported.
- Corrective Action
Verify that both the client and Data ONTAP® support and are configured for SMB2 or later.
- Syslog Message
For Vserver "%s", the vscan connection request coming from the client "%s" is rejected because it is not supported for SMB1.
- Parameters
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the client.
