ONTAP EMS reference
nblade.vscanconnreqonsmb1 events
nblade.vscanconnreqonsmb1 EMS events occur during a client attempt to establish a vscan connection over SMB1, which is not supported.
Nblade.vscanConnReqOnSMB1
Severity
ERROR
This message occurs during a client attempt to establish a vscan connection over SMB1, which is not supported.
Corrective Action
Verify that both the client and Data ONTAP® support and are configured for SMB2 or later.
Syslog Message
For Vserver "%s", the vscan connection request coming from the client "%s" is rejected because it is not supported for SMB1.
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the client.
