ONTAP EMS reference
volcreate.fsid events
volcreate.fsid EMS events occur when flexible volumes were created with file system identifiers (FSIDs) which conflict with existing volumes.
volcreate.fsid.dup
Severity
ERROR
Flexible volumes were created with file system identifiers (FSIDs) which conflict with existing volumes. This can happen when aggregates are forced offline.
Corrective Action
  1. run 'aggr online' on all offlined aggregates. some of the old vvols will be forced offline due to the FSID conflict. 2. run 'vol restrict' and 'vol rewrite_fsid' on the new vvol 3. run 'vol online' on each flexible volume that was forced offline in step 1 above.
Syslog Message
Volume %s's fsid 0x%x conflicts with a volume owned by vfiler %s.
volName (STRING): Name of the volume created
FSID (INT): FSID of the volume
vfiler_name (STRING): The vfiler which owns the existing offlined volume with the same FSID.
