volcreate.fsid events
volcreate.fsid.dup
- Severity
ERROR
- Description
Flexible volumes were created with file system identifiers (FSIDs) which conflict with existing volumes. This can happen when aggregates are forced offline.
- Corrective Action
run 'aggr online' on all offlined aggregates. some of the old vvols will be forced offline due to the FSID conflict. 2. run 'vol restrict' and 'vol rewrite_fsid' on the new vvol 3. run 'vol online' on each flexible volume that was forced offline in step 1 above.
- Syslog Message
Volume %s's fsid 0x%x conflicts with a volume owned by vfiler %s.
- Parameters
volName (STRING): Name of the volume created
FSID (INT): FSID of the volume
vfiler_name (STRING): The vfiler which owns the existing offlined volume with the same FSID.
