asup.post events
asup.post.drop
Severity
ERROR
This message occurs when the AutoSupport® mechanism quits trying to post to the NetApp URL after having retried for the specified number of times.
Corrective Action
Use the "system node autosupport check show-details" command to check for connectivity or certificate errors. If the connectivity check shows no errors and if the problem persists, contact NetApp technical support for further assistance.
Syslog Message
AutoSupport message (%s) was not posted to NetApp. The system will drop the message.
subject (STRING): AutoSupport message title.
