asup.post events
asup.post.drop
- Severity
ERROR
- Description
This message occurs when the AutoSupport® mechanism quits trying to post to the NetApp URL after having retried for the specified number of times.
- Corrective Action
Use the "system node autosupport check show-details" command to check for connectivity or certificate errors. If the connectivity check shows no errors and if the problem persists, contact NetApp technical support for further assistance.
- Syslog Message
AutoSupport message (%s) was not posted to NetApp. The system will drop the message.
- Parameters
subject (STRING): AutoSupport message title.
