ONTAP EMS reference
raid.aggrvote events
raid.aggrvote EMS events occur when ONTAP encounters issues associated with mirror vote operations and the replicated database (RDB).
raid.aggrvote.pullNotOk
Severity
INFORMATIONAL
This message occurs when the mirror vote pull from the replicated database (RDB) to the mailbox fails. SyncMirror® aggregates with only one plex will be kept offline. The mirror vote pull is retried automatically.
Corrective Action
(None).
Syslog Message
RAID: mirror vote pull from the RDB failed. SyncMirror aggregates with only one plex will be kept offline.
(None).
raid.aggrvote.updateNotOk
Severity
ERROR
This message occurs when the mirror vote update to a replicated database (RDB) fails.
Corrective Action
The update is retried automatically. If the condition persists, contact NetApp technical support.
Syslog Message
RAID: mirror vote update to the RDB failed with error %s for aggregate UUID %s (num of plexes %d; ids: %d, %d).
reason (STRING): Reason for the failure.
aggregate_uuid (STRING): Universal Unique Identifier (UUID) of the aggregate.
num_plexes (INT): Number of plexes recorded in the mirror vote.
plex0_id (INT): ID of plex 0 in the mirror vote.
plex1_id (INT): ID of plex 1 in the mirror vote.
raid.aggrvote.updateOk
Severity
NOTICE
This message occurs when the mirror vote update to a replicated database (RDB) succeeds.
Corrective Action
(None).
Syslog Message
RAID: mirror vote update to the RDB succeeded for aggregate UUID %s (num of plexes %d; ids: %d, %d), action %s.
action_type (STRING): Action performed on the RDB table entry. "CREATE" or "MODIFY".
