ONTAP EMS reference
raid.aggrvote events
raid.aggrvote.pullNotOk
Severity
INFORMATIONAL
This message occurs when the mirror vote pull from the replicated database (RDB) to the mailbox fails. SyncMirror® aggregates with only one plex will be kept offline. The mirror vote pull is retried automatically.
Corrective Action
(None).
Syslog Message
RAID: mirror vote pull from the RDB failed. SyncMirror aggregates with only one plex will be kept offline.
(None).
raid.aggrvote.updateNotOk
Severity
ERROR
This message occurs when the mirror vote update to a replicated database (RDB) fails.
Corrective Action
The update is retried automatically. If the condition persists, contact NetApp technical support.
Syslog Message
RAID: mirror vote update to the RDB failed with error %s for aggregate UUID %s (num of plexes %d; ids: %d, %d).
reason (STRING): Reason for the failure.
aggregate_uuid (STRING): Universal Unique Identifier (UUID) of the aggregate.
num_plexes (INT): Number of plexes recorded in the mirror vote.
plex0_id (INT): ID of plex 0 in the mirror vote.
plex1_id (INT): ID of plex 1 in the mirror vote.
raid.aggrvote.updateOk
Severity
NOTICE
This message occurs when the mirror vote update to a replicated database (RDB) succeeds.
Corrective Action
(None).
Syslog Message
RAID: mirror vote update to the RDB succeeded for aggregate UUID %s (num of plexes %d; ids: %d, %d), action %s.
action_type (STRING): Action performed on the RDB table entry. "CREATE" or "MODIFY".
