wackiron.panic events
wackiron.panic.warning
Severity
ERROR
This message occurs when the bootarg 'wackiron_enforce_panic' will cause the system to panic after the next boot if you do not run wafliron on the affected volume before the completion of the next boot.
Corrective Action
Run wafliron on the affected volume. From the boot menu, run 'wafliron'. From the dblade CLI, run 'aggr wafliron start [aggr-name]'.
Syslog Message
Warning: System will panic if wafliron is not run on '%s' before the next boot is complete.
volname (STRING): Name of the aggregate.
