wackiron.panic events
wackiron.panic.warning
- Severity
ERROR
- Description
This message occurs when the bootarg 'wackiron_enforce_panic' will cause the system to panic after the next boot if you do not run wafliron on the affected volume before the completion of the next boot.
- Corrective Action
Run wafliron on the affected volume. From the boot menu, run 'wafliron'. From the dblade CLI, run 'aggr wafliron start [aggr-name]'.
- Syslog Message
Warning: System will panic if wafliron is not run on '%s' before the next boot is complete.
- Parameters
volname (STRING): Name of the aggregate.
