The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nand.predict events
Creating your file...
Your file is ready
nand.predict.fail
- Severity
ALERT
- Description
This message occurs when Data ONTAP® determines that failure is forthcoming for the associated flash device on the NVRAM module.
- Corrective Action
Replace the device to prevent future failures. Contact technical support for assistance.
- Syslog Message
NVRAM destage Failure predicted for device: %s.
- Parameters
device (STRING): Name of the device.
