nand.predict events
nand.predict.fail
Severity
ALERT
This message occurs when Data ONTAP® determines that failure is forthcoming for the associated flash device on the NVRAM module.
Corrective Action
Replace the device to prevent future failures. Contact technical support for assistance.
Syslog Message
NVRAM destage Failure predicted for device: %s.
device (STRING): Name of the device.
