nand.predict events
nand.predict EMS events occur when Data ONTAP® determines that failure is forthcoming for the associated flash device on the NVRAM module.
nand.predict.fail
- Severity
ALERT
- Description
This message occurs when Data ONTAP® determines that failure is forthcoming for the associated flash device on the NVRAM module.
- Corrective Action
Replace the device to prevent future failures. Contact technical support for assistance.
- Syslog Message
NVRAM destage Failure predicted for device: %s.
- Parameters
device (STRING): Name of the device.
