vifmgr.hv events
vifmgr.hv.nohostconfig
Severity
ALERT
This message occurs when no Hypervisor host configuration is available. This is required by ONTAP® software to monitor the health of the hypervisor uplinks.
Corrective Action
Verify the Hypervisor host configuration. Without it, ONTAP cannot monitor the health of the hypervisor uplinks, preventing data LIFs from failing over if the uplink were to go down.
Syslog Message
The %s health monitor cannot access the Hypervisor host configuration.
monitor (STRING): Health monitor name.
vifmgr.hv.nosnmpconfig
Severity
ALERT
This message occurs when no Hypervisor SNMP configuration is available. This is required by ONTAP® software to monitor the health of the hypervisor uplinks.
Corrective Action
Verify the Hypervisor SNMP configuration. Without it, ONTAP cannot monitor the health of the hypervisor uplinks, preventing data LIFs from failing over if the uplink were to go down.
Syslog Message
The %s health monitor cannot access the required Hypervisor SNMP configuration.
vifmgr.hv.nouplinkmapping
Severity
ALERT
This message occurs when no Hypervisor uplink mapping is available for the specified port. This is required by ONTAP® software to monitor the health of the hypervisor uplinks.
Corrective Action
Verify the Hypervisor uplink mapping configuration. Without it, ONTAP cannot monitor the health of the hypervisor uplinks, preventing data LIFs from failing over if the uplink were to go down.
Syslog Message
The %s health monitor cannot access the Hypervisor uplink mapping configuration for node %s port %s.
node (STRING): Name of the node.
port (STRING): Name of the port.
vifmgr.hv.nouplinkstatus
Severity
ERROR
This message occurs when there is an error obtaining the Hypervisor uplink status for the specified port.
Corrective Action
Verify the Hypervisor’s host and SNMP configuration.
Syslog Message
Unable to obtain the hypervisor uplink status for port %s with hypervisor uplinks %s.
uplinks (STRING): List of hypervisor uplinks associated with the port.
