      san.optimizedpersonality events
san.optimizedPersonality.mismatch
- Severity
ERROR
 - Description
This message occurs when a mismatch is detected between the san-optimized personality of a node and the cluster.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
The san-optimized value "%s" does not match the san-optimized value of the cluster.
 - Parameters
san_optimized (STRING): The san-optimized value for the node.
object_type (STRING): Type of resource object under notification. For this EMS, the object_type will always be NODE.
object_uuid (STRING): UUID of the resource object. For this EMS, the UUID will be of the node.
