The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
san.optimizedpersonality events
Creating your file...
Your file is ready
san.optimizedPersonality.mismatch
- Severity
ERROR
- Description
This message occurs when a mismatch is detected between the san-optimized personality of a node and the cluster.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
The san-optimized value "%s" does not match the san-optimized value of the cluster.
- Parameters
san_optimized (STRING): The san-optimized value for the node.
object_type (STRING): Type of resource object under notification. For this EMS, the object_type will always be NODE.
object_uuid (STRING): UUID of the resource object. For this EMS, the UUID will be of the node.
